Repair guides and support for cars, trucks, and SUVs manufactured by GMC.
149 Questions View all
rear heater keeps running even though the vehicle is off.
The rear heater resistor is supposedly bad, how do I change out this part.
Comments:
Hi, What year and model is your vehicle? Also are you referring to the rear window demister or is there a separate heater in the rear of your vehicle? Also bit confused by your 'keeps running even though the vehicle is off'. Is the control for the demister? /heater? off and it still works or is the ignition switched off and it still works, please clarify exactly what the problem is?
by
Rear heating and cooling gmc envoy xl 2003. The fan runs with ignition on, removed the fuse.
by
The system is located in the rear right area
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Hi Scott,
Below is a quote, among others, from this link http://www.amazon.com/ACDelco-15-72813-O... which describes the fix for your GMC Envoy XL, as well as other GMCs with a similar problem.
You may be able to find the part cheaper somewhere else. This is just to show what may be the problem with your vehicle.
This is the fix for those of you whose rear AC fans run on after shutting the car off. I installed it in a 2003 GMC Envoy, but it is a replacement for many GM models. It is mounted on the external side of the rear AC unit and is a pain to get at, but worked like a charm once installed.
Hopefully it is of some help.
Score 3
Add a comment
Add your answer
ScottB will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 605
