A 3.4 oz., white Android phone with a 4” touchscreen and a 5 MP camera. Released in 2013 on the Boost Mobile network. Recognized with model number SPH-M840.
7 Questions View all
Why can't I do a factory reset? Why does it keep rebooting?
I have a Prevail 2. Boost phone. The phone powers on, and loads everything. and about 20 seconds later it reboots. It will do this repeatedly, until the battery is removed. I tried power button & vol ^ button for a hard reset, selected wipe data/factory reset, then selected yes, and it showed confirmation of wipe, and gave the option to reboot now, and it rebooted back to my homescreen, same home picture, same apps, same lockscreen photo.........WHAT AM I MISSING?
Comments:
I will try this asap! thanks for helping out, I am one irritated geek with this one
by
Add a comment
1 Answer
Chosen Solution
Hi,
It appears that you are doing it right.
Here is a link try using methods 2 or 3 and see if they will work.
http://www.hardreset.info/devices/samsun...
Score 3
Comments:
These methods are valid, but unfortunately, I was unable to successfully complete the factory reset. Thanks anyway. The phone reboots about every 30 or 40 seconds. I haven't found a way to stop it from rebooting. I thought a factory reset would do the trick, but I can't even do a reset
by
Hi,
If you can (and have the time to do it) go into Settings > Apps (maybe known as Applications) > Downloaded and start to "force stop" the downloaded apps only. Tap each app and then if you can tap 'Force Stop'. You probably only have time to do 1 or 2 each time before the reboot occurs. I'm wondering if an app (non system one) is preventing you from resetting. If you do stop an app and the rebooting stops that may be the one causing the problem. Remember which one it is and as long as you are sure it is not a system app (google the name to verify whether it is or not if you are unsure) uninstall it and see if the problem goes.
by
I have time to force stop on one or 2, and I've went through each one in the downloads list, and it still does it.
by
@techtinker I have had this happen a few times on s3's and i found if i remove the battery and held the power key down for 60seconds or so then reinstalled the battery and went through the reset process again it would work . They are similar phones it may work cant hurt to try
by
Add a comment
Add your answer
Pamela Dodson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 122
