Fix Your Stuff
Right to Repair
Store
Kyocera's Hydro Vibe is a waterproof touch screen phone with a 4.5inch impact-resistant screen and Smart Sonic receiver technology
16 Questions View all
What might cause short battery life?
My Kyocera Hydro Vibe is having issues with its battery life. The battery life started to deplete rapidly and now the phone will not stay on for longer than a few seconds after charging it for an extended period of time
Add a comment
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
yüksek ihtimalle pil bozulmuş ama cihazda da sorun olabilir, yeni bir pil ile dene
Add a comment
You can try to restart your phone, once in a while you have to restart your phone because it can counter a common issue. If that doesn't work, you can close your unused app on your phone that might drain your battery. You can also check your battery, you might need to replace your battery. You can also go to the troubleshooting link ---Kyocera Hydro Vibe Troubleshooting
Add a comment
Add your answer
Phillip Newman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 294
