Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
replaced battery, now it won't charge
replaced battery, now when i plug it into ac charger nothing happens
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
check dock connector no.4 is on properly and screws next to sticker that says "do not remove" as it connects motherboard to battery.
Score 2
Add a comment
if the connector no. 4 is on properly and the screws good, what next? The battery had 28% when installed and charged a little (up to 30%) then went down and won't charge.
Comments:
put the old battery (if you still have it) back in and see if it charges. It may be you have a bad battery. Batteries lose 30% capacity to charge per year just sat on a shelf so if you've got a "new" battery that's been on waiting a while to be shipped this may be the problem. Send it back and try a different vendor.
by
Add a comment
Could it possibly have been only the charging port that was bad and not the battery?
Add a comment
Add your answer
Bill Clark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,060
