Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
dead battery + open I boot = no ios
hey guys i have a iphone 3g that has open i boot and a dead battery.
So my problem is that it wont boot to ios.But it can boot to the console and android,android kinda dosent work it works for 10 secs and it reboots.
I tried 2 amp no luck. pls help can i do something throgh the console or remove open i boot using a pc please answer. I havw win8,1 pro btw
Score -1
Add a comment
1 Answer
Most Helpful Answer
You can definitely restore the device in DFU mode, but it probably wont help (it may even get stuck).
You are going to need to replace the battery. Make sure you do so with a 3G battery, as the 3GS battery looks the same but is different and will cause a similar issue
Score 1
Add a comment
Add your answer
board iphone dood will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
