The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
112 Questions View all
Screen is constantly flickering in purple/pink - what part is broken?
My galaxy tab 2 10.1 has a broken glass but has been working fine anyway. Now suddenly the screen is constantly flickering in purple and pink, the picture is at the same time jumping around, the lines making up the screen jumps at different directions, making it impossible to use. But the touchscreen responds, although I have to guess what I am touching when I can't see what's behind the flickering and jumping screen.
I wonder what part is broken, so I can try fixing it?
Add a comment
Chosen Solution
The flickering is caused by a broken lcd panel. If the touch stops responding the digitizer would be the broken piece. However large displays usually have both the digitizer and lcd bonded with glue. In that case it is easiest and quickest to just replace both pieces as a unit.
Score 1
Add a comment
It's caused by a damaged lcd display, check following links for the replacement tutorial and replacement part if you'd like to repair it by yourself, hope it helps, good luck.
Score 1
Add a comment
Add your answer
Sara will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 65
Past 30 Days: 244
All Time: 3,281
