Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
1197 Questions View all
Why won't my phone power on. I have all genuine parts.
I haven't dropped it, replace any parts, nor exposed it to water damage . I tired the hard reboot, plug it into different apple charges and cord, and into iTunes on my mac and MacBook Pro. Still won't work. Note: only thing i didn't use is the finger id touch pad from day one. I covered it up.
Comments:
Hi,
Can you post a photo of the motherboard?
by
the phone is two months out of warranty.. I can take a picture of the motherboard, but i don't have one of those microscope cameras...
by
Taking my time with extracting the logic board out. Inspired by Jessa Jones and her made skills. Thank You... In doing so, I notice that the adhesive tab in step23 is missing... looks like mtl to mtl could have touch between that and the digitizer sheet mtl some how. there nothing btwn that. I see no arc marks though. Any comment on that possibility of shorting out?
by
how do u add a picture? I tried below and it didn't take
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
If you change the battery and it powers on, then you may have damaged the Tristar chip (known commanly as the U2 IC)
This is damaged by cheap chargers.
This is probably why you can't get it to charge.
Try a new battery, it will probably turn on and be able to charge, but if the battery dies and doesn't charge, then this confirms the U2 IC problem. :-)
Score 2
Comments:
i ordered it a couple of days ago. Well see.....
by
Okay. dropped a battery in it and nothing happen.....
by
Do you even know if that was a charged battery?
by
Add a comment
Most Helpful Answer
conkar, since you "haven't dropped it, replace any parts, nor exposed it to water damage" your phone should still be covered under warranty. Take it to where you bought it from and have it replaced.
Score 4
Add a comment
When you opened your phone up to look at the board did you happen to disconnect the battery? I have had to reset many 5s and 5c phones (no 6's yet) simply by disconnecting and reconnecting the battery. Hard reboots, different chargers or hooking it up to a computer would ever turn it on.
Score 1
Comments:
I did disconnect the battery and reconnect it before i took out the pcb. just installed a fresh battery and nothing happened..... idk what's going on....
by
Add a comment
Pls take a look at this. Behind the sims card. that doesn't look right, but IDK
Add a comment
here is a second photo
Add a comment
Add your answer
conkar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 146
