Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4258 Questions View all
Blueooth/WLan pretty weak, antenna broken?
Hello,
since i dropped my iPhone 6 i had an issue with the BT and Wifi connection. I am able to connect both but the signal is pretty weak, in example bluetooth is stable for a radius of three to four feet.
I already checked the part of step 14 in this teardown (iPhone 6 Teardown) but there aren´t any visible defects. What should i do? Do you think its worth to change this part?
In my opinion it have to be a problem with the antenna because there is a connection, just a weak one. What do you think?
Hope you can help me.
Greetings
Malte
(Not a native speaker, so sorry for my $@$*!& english)
Update (02/20/2016)
Comments:
Anyone can help?
by
Add a comment
1 Answer
Chosen Solution
Step 14 is not related. Check step 29-31 on the following guide, also the weird F-shaped RF flex on the back of the board.
iPhone 6 Rear Case Replacement
Score 2
Comments:
Checked that part and cant find something wrong :-/
I took some pictures from the inside of my iPhone, maybe you see more then me.
by
What about the F-shaped (or double L shaped) cable connections that you have the past number redacted? Are there damages or not connected properly?
by
I dont rly know which cable you mean, can you mark the position on one of my posted pictures and post it again?
by
The second picture, where you put the red bar onto it
by
Okay, checked it. There are NO visible destructions. The red bar just covers a number because i dont know if this number have be a secret.
Any other options? What should i do?
by
Show 1 more comment
Add a comment
Add your answer
Malte He will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 673
