Repair guides and troubleshooting for the Acer Aspire 5, a series of laptops on the Windows OS by Acer.
Access to ACER ASPIRE V5 471 Bios , want to change win
Unfortunatly i have acer aspire v5 471p , and want to change window 8.1 to win10
No Access to ACER ASPIRE V5 471p Bios
But there is no BOOT menu option or setup option ,
I have tried f2,f8, f10 and f12 neither have worked.
No key is workinG to booT it, plz help me .
Score 2
3 Comments
Is there any one ???
by
try delete when booting . spam the daylights out of on startup
by
disable the secure boot and fast boot look for csm in boot menu disable it be sure your os flasdrive is inerted then save and exit . note press Esc to display bios
by
Add a comment
Chosen Solution
Hi,
To access BIOS in Win 8.1(or Win 10) turn off fast startup mode then shutdown the laptop, (do not select restart this one time). On starting again you should be able to access BIOS in the normal manner.
Here is a link which shows you how
http://ccm.net/faq/31793-windows-8-1-how...
Score 3
2 Comments:
Nope still it is not working :(
by
I turnoff fast startup mode , but again it is not booting with any key and also not showing the setup , which comes in start
by
Add a comment
Hi,
Have you tried this?
http://acer-au.custhelp.com/app/answers/...
Score 3
Add a comment
No . Still it is not working
Add a comment
Go to the system BIOS via the advanced startup and change the boot priority order putting usb at the top and change boot type to Legacy then reboot and press F12 and run dban or windows 10 or whatever
Add a comment
Add your answer
NoBody will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 30,218
