No touch ID after motherboard replacement - changed home buttons
I know that home buttons are paired with motherboards, I swapped over the motherboard from phone #1 into phone #2. I connected the screen from phone #1 onto phone #2, The home button works perfectly but touch ID is greyed out.
Are the dock connectors linked to TOUCH ID as well? I only swapped the motherboard and screen.
Thanks
2 Comments
You probably did not connector is securely. Try disconnecting it and reconnecting it. Either that, or you connected when the phone was on and shorted the home button.
by Jake
I have tried to take it on and off a few times and the issue still occurs. So the home button is paired with the motherboard only and no other parts?
by Brick50
