Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
521 Questions View all
Can I switch my trackpad to a different top case?
I'm buying a Top case with keyboard +battery etc. from cmd macparts but it does not include a Track Pad assembly. Is it possible to remove the trackpad from my original topcase and install it into the new one? As far as I can tell the trackpad is functional, it's only the keyboard and battery switch which are damaged from a water spill.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Yes, you can remove the old trackpad and put it into the new upper case.
Follow this IFIXIT guide: MacBook Pro 15" Unibody Mid 2012 Trackpad Replacement. While this is for a newer model follow this guide first to get the parts out of the upper case: MacBook Pro 15" Unibody Mid 2010 Upper Case Replacement.
Score 2
Add a comment
Add your answer
James Doe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 50
