2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Questions View all
No Backlight or Picture - How to check LCD Fuses
I bought a computer that needed an LCD. I got a new LCD display and plugged it into the motherboard, but nothing happened. I tested the LCD by plugging it into another MBP I have and it worked fine. The LCD port on the mobo looks fine, and the computer works great on an external monitor.
I followed this:
fuse location and type is the same for a Mid-2012 Retina 15"
and get a reading of 0 ohm across Fuse F9700, so this would mean its good right? I shined a bright light behind the apple during boot up and can not see anything. Im not sure what fuses i need to test or how to tell if they are bad. Can someone help me out here?
Score -1
8 Comments
What happens when you plug in an external monitor, does that work?
by
Yes with HDMI the computer works fine.
by
With a flashlight shine it through the Apple Logo (poor mans backlight) you should be able to see your desktop icons, do you?
by
Haha I answered both those questions already =) No I dont
by
Do you know your model number should be like A1425/A1502
by
Show 3 more comments
Add a comment
1 Answer
Most Helpful Answer
OK, so we know the display assembly its self is good and we know the systems logic board video services is good. So that limits the problem down to the connector on the logic board.
Can you take some good detailed images of the connector solder joints and the connectors pins. I suspect we'll see something. Post them in your question so we can see them.
Are you sure you got the correct display assembly for this system?
There is no fuses for the data interface only for the backlight power lines.
Score 1
3 Comments:
The plug looks good. I took pictures here:
https://www.dropbox.com/sh/x03bdx2a1dphr...
And I bought the lcd for the a1398 here:
http://m.ebay.com/orderDetails?itemId=30...
by
Well, the connector looks clean from what I can see. The markers are not turned so the logic board on this side did not get wet (at least the markers didn't get hit). So I'm thinking the part is not correct or bad. Sadly, I can't see your eBay link as I would need your user info. Can you take some pics of the cable end to be sure the cable end is OK.
by
Here is the link to the screen:
http://www.ebay.com/itm/For-15-MacBook-P...
I have a mid 2012 retina 15" A1398 and I plug it into that and it works fine.
by
Add a comment
Add your answer
bhollehday will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,349
