How do I wire a tachometer
how do i wire a tachometer on a 1993 jeep grand cherokee
jimmiller1940, as a general answer since we do not know which tach you have, most aftermarket tachometers only have 3 or 4 wires that need to be connected. Usually a green wire for the tach, red for power, black for ground, and white or yellow for the back light. The power wire that gets connected to a 12 volt ignition source, the tach signal wire that connects to the coil or the designated signal wire in your cars wiring diagram.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 945
1 Comment
what make and model is your Tach? Post some images of the connectors with your question. Use this guide Adding images to an existing question for that
by oldturkey03
