A Bluetooth speaker for mobile devices and tablets that can make phone calls for the paired device . Released in Fall 2014.
17 Questions View all
What is this loose part that broke off from the circuit board?
Its a cube, about 10mm tall, 14mm across and has the number 100 stamped on the top.
It was soldered to the board on the upper right side behind the right speaker.
Score 1
Comments:
post an image of your part with your question. Adding images to an existing question
by
I had the same thing falling off of my JBL Flip 2. A 6R8 module here. After ordering a new module and soldering it, the thing still doesn't work.
by
Add a comment
Chosen Solution
It is, or rather was ;) , a 10uH inductor. Parts such as these are used in switch mode DC/DC converters, and switch mode audio amplifiers.
Its ferrite shell has cracked, which means that the component can no longer be used and must be replaced.
Score 3
Comments:
Thanks a ton!
I found a part that fits the description you gave and looks very similar to the part I have, but it is cylindrical instead of a cube.
Do you think that will be an issue?
by
Hard to tell. Inductors can be rather fussy components to replace.
Can you post a link to a description of the part you found?
by
Inductors of this type are suitable, but you'd need one with a bit higher current rating. This one's close:
http://uk.farnell.com/multicomp/mcsdrh73...
or maybe this one:
http://uk.farnell.com/multicomp/mcsdrh12...
by
Hi, mine is not cracked but it is just loose on one side. I put there some kind of hard foam to keep it placed on the motherboard - i am not a tech guy so my question is that it just needs to be connected back (not to be loose) ? can somebody post picture or a manual how to do that or should i take it service.
Right now it is working but i do not know untill when the foam will give enough pressure for the part to be on the mobo.
Thank you very much.
Best regards
Dusan
by
Show 6 more comments
Add a comment
We removed the unit (inductor) and epoxied it off the board then soldered a coated wire from the circuit board connections to each of the units two connectors. In this way, we created a solid electrical connection and physical mounting.
Add a comment
It reminds neodymium magnet
Score -2
Add a comment
Add your answer
tigraham1988 will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 175
All Time: 3,049
