The LeapFrog LeapPad Platinum 31565 combines a 7’’ high-resolution, multi-touch screen with a powerful quad-core processor. It is the latest model in LeapFrog’s line of learning tablets.
11 Questions View all
How do I replace the battery in the LeapFrog Platinum?
How do I change the battery? The company says it cannot be replaced but I want to know for sure.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I'm assuming you want to replace the battery because you are having issues with battery life or because your LeapPad won't turn on. May I suggest checking out the troubleshooting page to rule out a simpler solution before you tear your device apart? The battery is kind of a pain to replace so I want to help you avoid that if I can!
If you determine the battery does indeed need to be replaced, it is possible to do so. My team and I will be writing a battery replacement guide very soon, so keep a look out for that!
Comments:
The battery replacement guide is updated, you can check it out now.
by
Add a comment
Add your answer
David Lee will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 124
All Time: 2,017
