Fix Your Stuff
Right to Repair
Parts & Tools
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
84 Questions View all
Is Usb boot Supported?
Is usb boot supported on a 1.25Ghz mac mini?
Comments:
Would you mind telling us the actual problem is?
by
Add a comment
Chosen Solution
If you have another Mac, use the firewire cable to hook up to and use Target Mode.
http://osxdaily.com/2010/04/07/how-to-bo...
Score 3
Comments:
If you do, your system requires Leopard (10.5.8) or older. Make sure the other Mac is not running anything newer.
by
@danj - it has to be as 10.6+ requires an intel processor.
by
I think we're saying the same thing here. The PowerPC Mini can only go up to Leopard (10.5.8) the newer Intel Solo & Duo models can support up to Snow Leopard (10.6.8)
by
Yes, we are, but you're a Boston Yankee and I'm a West Texan and we talk differently ;-)
by
I hope we put on our pants on the same way! ;-}
by
Add a comment
Most Helpful Answer
Sadly no, only the optical drive disk the system came with or FireWire HD that is setup with the correct OS for your system.
Score 3
Comments:
so if i have a firewire hdd can i use that to install the os?
by
Yes, as long as it has the correct OS and is setup to be bootable (OS fully installed).
by
Add a comment
Add your answer
Cameron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 594
