Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1225 Questions View all
Replacement trackpad is laggy
Hi! I purchased my Mac from a fellow friend who needed money. And he gave it to me with a broken trackpad on the top left edge. Coming back to today, I purchased the replacement trackpad and I could and did replace the factory one. Thing is that when installed I proceed to test it, and it's somewhat like laggy from the half to the top of the trackpad itself. (Don't know if I explained myself properly). Plus I couldn't do a drag and drop action using two fingers. What could it be? Installed back the factory one and it works like a charm. Is it the trackpad thats not fully original or is it defective?
Thanks.
Score 2
Comments:
Is the battery swollen?
by
Add a comment
Most Helpful Answer
Try going under the Apple in the upper left hand corner to System Preferences > Trackpad and reset the speed and see how it is currently set up.
Score 2
Add a comment
Try to swap the ribbon cable from your old trackpad to the the new one. If you have the same problem then the new trackpad is faulty. Ask for a replacement.
Score 1
Comments:
I tried to remove it but it is glued to the trackpad itself so I'm a bit afraid it might ruin.
by
you may try to heat the cable a little with a hair dryer. If you're afraid of damaging the cable then just contact the seller and ask for a functional trackpad.
by
Add a comment
Add your answer
Dennys Ortega will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 118
