The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
281 Questions View all
What to buy to replace a damaged Dock Connector?
The dock connector on my iphone 1G was broken. What replacement could I buy from you to replace the connector? Could I actually use the iphone 3G dock connector? Appreciate your response.
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
no, you cannot replace 1g dock with 3g. connection is completely different. instead, you need to swap the whole midboard... it is possible to swap just the dock connector, but that is EXTREMELY delicate operation. i strongly recommend you, to buy the assemmbly. you will save a whole !&^@ of problems... unfortunaltely, you cannot buy it on iFixIt eshop, it is unavailable... try later, or search different supplyier.
Score 1
Add a comment
I have the same problem! I'm buying that piece Dock Connector, but I see that has a battery to one side. and seeing the piece says that does not take the microphone included. I'm in doubt, because I only see a small battery in the connector Dock Connector.this is the part that you say?
Charging Charger port flex ribbon for iphone 2G
Add a comment
@Julias
I repair the iphone 1st gen and that model ONLY.
I have used but tested dock connectors, also the assembly which is less messy. but i am not sure if i can supply my email here or not.
@palokiller
It is Not a battery to the side, it is the home button connector and actuator.
Add a comment
Add your answer
Julius Reyes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,637
