Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
I replaced the charging port, now my touch id will not work?
A couple of days ago i replaced my charging port on my 5s now my touch id will not work.
Score 1
Add a comment
Chosen Solution
It's possible you damaged your flex cable, on your home button. Try putting the old lightning dock (charging port) and then see if the Touch ID works, to make sure the new lightning dock (charging port) isn't the problem
Score 3
6 Comments:
The reason i took the old charging port off was because it wasnt charging the phone, the home button still works on the current charging port i have in the phone. i tried cleaning the old charging port out but that didnt work so i replaced it with an old one from an old iphone 5s, since you cant individually replace the charging port i replaced the whole assembly, audio jack, microphone, and everything else associated with the whole assembly. So maybe a brand new charging port assembly?
by
Ok, I think I know what happened here. It is possible that you need a new charging port. However, what I think happened is that you turned it on and tested the display assembly, and then disconnected the home button cable. Either way. Disconnect the display and home button assemblies. Disconnect the battery, reconnect everything and put it in its place, the whole thing back together. Then turn your phone on and try it
by
i replaced the battery before anything, turned the phone on with the old charging port in place, the home button was disconnected before i turned the phone on once the phone was turned on i connected the cable and the touch id worked, the only problem was the phone wouldnt charge, therefore i replaced it with the charging port assembly from my old iphone aand then touch id would not work. Still recommend doing what you said in the comment above? thank you
by
Yeah, I've had that happen to me before. Just disconnect and reconnect
by
any specific order it should be connected in?
And thanks again
by
Show 1 more comment
Add a comment
Just do a hard reset (press standby button + home button till the phone restarts), it will start working. That solved the problem for me
Score 1
Add a comment
For me it was the connection of the new lightning port assembly. Everything worked except the Touch ID. It even charged. I just connected the old one (Connection on the logic board and the Touch ID) and powered the phone on and voila the sensor worked. then I reconnected the new one properly and suddenly the sensor works! so check if the new assembly has a proper connection or reconnect it.
Add a comment
Hard reset worked for me. 100% functional with $10 charging port board (iphone SE)
Add a comment
Add your answer
davidschoenberger1010 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 6,191
