The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465 Questions View all
PS3 sometimes starts up, but always freezes, even in safe mode
Hello everyone!
I've tried searching for this issue, but I haven't been able to find a solution.
I have a used PS3 Slim, on which I installed the latest 4.78 OS, but after that, it started freezing up.
Usually when I press the power button, the LED turns green but nothing shows up and the PS3 switches off and the LED shows nothing. Upon pressing the start button, the LED turns back to red and the PS3 goes back to stand-by.
At this point, the PS3 does not go into safe-mode either.
If I take out the power cord and hold the power button for sometime and then try turning it on, it works, but only for a short time and then in the XMB, it freezes up again, so the motherboard, etc. I think work. Using this trick, I booted up the PS3 into safe-mode also, but it still froze.
I think the problem maybe with the HDD, so I tried plugging it into the PC and running HDD Recovery to search for bad sectors. The program found one delayed sector and fixed it, but that didn't solve the problem either. I then formatted the HDD and inserted it into the PS3, but it doesn't seem to work either.
If I try to switch on the PS3 without a HDD, then the system says it can't find a storage media.
I guess I will now try to get a used HDD and try with that, but if anyone has any advice, please tell me.
Thanks!
Add a comment
Most Helpful Answer
It has nothing to do with your HD probably. Symptoms are there but problem is with your Motherboard which has to be reheated and processor repasted . Procedure is described here on IFixit as YLOD (yellow light of dead) problem. You need Screwdriver, heat gun, silver paste, old credit card and a bit of courage. With heating and cooling process you will be comfortably finished in 2 hours.
Score 1
2 Comments:
%#*@, I was hoping that would not be the case, but I guess I'll give it a try! Thank you so much for your answer :)
by
Hey so I did this, but I think it's gotten worse, the PS3 won't show anything now no matter what I do. Any suggestions? Or should I just call it quits?
by
Add a comment
ya you shouldnt have listened to that guy, if your not an expert dont attempt difficult repairs that may or may not be necessary, ESPECIALLY if you don’t know what the F%#@ you’re doin
Add a comment
same thing happening to me tho. I Play A Little And Then It Freezes Even In Recovery It Freezes And My Ps3 Is In 4.87.it Started To Corrupt Data Not Responsing CD Games That What Happens When You Update The S… Ps3 I Want A New One And I Cant Get Because I Have…
Add a comment
My ps3 doesn't show on tv so i tried fixing it but when i power it on as soon as i click the power button it freezes INSTANTLY so it wont even let me hold the button long enough to get to safe mode? and i just got bo2 and bo1 back
Add a comment
Add your answer
Ramneek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 4,104
