The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
341 Questions View all
Where are the power pads to short it on?
Im looking for the pads to touch to short it on to check to see if my keyboard is broken.
Add a comment
1 Answer
Chosen Solution
David Molinari you can do this by either shortening pin 5 of the keyboard connector briefly to ground. You can also use the debug pads as pointed out.
Score 3
Comments:
Thank you very Much oldturkey03!
by
Hey! When I short the two pads it turns on but the fan goes on at full speed and doesn't stop. Where is keyboard connector 5 by the way? Thanks in advanced!
by
Hi, thank you so much!!!! I've been searching these power-on pads for so long...
I "only" have to replace the keyboard now.
by
Must i disconnect the keyboard in order to power up with power pads ?
by
francoisvdc no you do not.
by
Add a comment
Add your answer
David Molinari will be eternally grateful.
Past 24 Hours: 13
Past 7 Days: 100
Past 30 Days: 412
All Time: 6,888
