Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
2,4 ghz wifi very weak, 5 ghz wifi works well
2,4 ghz wifi signal is very weak on a iPhone 6. It only work when the phone is beside the router. Just one step from the router and the signal is still there but weak and the internet is stop working.
But the 5ghz wifi works well with normal range.
I have seen this problem of a few iPhone 6. And i am sure it is hardware related, i have tried network reset and also a full restore with no succes.
Is there a solution to this?
Score 2
1 Comment
It could be an issue with the wifi antenna or the actual chip on the motherboard that handles the wifi.
by
Add a comment
1 Answer
Chosen Solution
Check the screws and clips on the top bezel, and the flat RF bridge cable on the upper part of the phone.
Score 2
Add a comment
Add your answer
kop will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 185
