The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3764 Questions View all
No speaker sound or headphone sound?
Hello,
After replacing the battery in my iphone 5s I ran into a mess of problems. Though the touch ID stopped working, I am not concerned. I noticed both the speaker and the headphone jack stopped working. I can get sound out of the lightning port as well as bluetooth audio, and audio out of the ear piece in calls.
Does this mean I should replace the dock connector and speaker? Is there perhaps a damaged ribbon cable?
Add a comment
Chosen Solution
Sounds like you might have bumped a connector loose. There is a small connector that sits just to the side of the battery connector, between it and the loudspeaker. Check and make sure you have that connected properly.
Score 1
Add a comment
Too bad I already ordered a new dock connector and speaker...
Because you solved my problem. I can't believe it. Sometimes the simplest answer is the best. I'll gladly waste the 10$. You are awesome, thanks so much!
Add a comment
Add your answer
Brian B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 54
