Nexus 5x screen showing colorful static
Reboot the phone and the display looks black.
Highlighting works after pressing the power button noise appears on the screen (see photo).
Phone is connected via USB to PC, flashing on the fastboot did not help. Disassembled, disconnect the connector and back append the display - without any changes.
Problem is sudden, the phone does not drop, charged by other chargers, it worked fine.
Have you done any work to the phone recently? Have you tried unplugging the battery for a few minutes?
by Toupee Scalper
Yes malfunction before I worked with the phone was flashed TWRP / bootloader / root. After flashing the phone worked fine, I rebooted it a few times, such problems do not arise.
After a fault, I disassembled it, disconnect the battery, the display, the camera, board. A few minutes later I collected it, the problem remained.
by Senya
Did you solve it? Just happened to me the same, but after a reboot
by Martin Bogado
Yes I change display module
by Senya
The display or even stuff from motherboard? I'll take it to repair
by Martin Bogado
