The current line of iPod Touch comprises six (6) different generations.
3276 Questions View all
What prevents the buzzer from working and can it be repaired?
My iPod Touch was repaired after it was dropped and the glass cracked. Since then the buzzer (can't really call it a speaker) has not worked. Has anyone else experienced this? What can be done?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
When you say that you can't call it a speaker, are you referring to the speaker and making a joke? I don't understand humor a lot of the time.
I'm going to continue to answer your question as if you're asking about the internal speaker going bad. Unfortunately, the speaker is soldered to a thin ribbon cable and is attached to the logic board. If you want to fix or replace it, then you'll have to follow the logic board guide for the 2nd gen or 3rd gen iPod touch, depending on which you have. The speaker is a small square that sits on top of the board. For better pictures of it, look at the teardowns.
Score 1
Comments:
Thanks for your reply. I refer to it as a buzzer because it is only an alarm and really doesn't reproduce sound. Headphones are needed to listen to music.
by
Then you must have a 1st gen, not a 2nd, or 3rd.
by
Isn't that the section I posted in?
by
Add a comment
Add your answer
Carl Arndt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 771
