Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Can I use iPhone 4s battery in iPhone 4?
I have an iPhone 4 with a dead battery. And an iPhone 4s with a flaky charging port. Can I put 4s's battery in the iPhone 4? Would it work as expected?
Score -1
Add a comment
1 Answer
Chosen Solution
The simple answer is no.
They use different connectors. :-)
Score 2
4 Comments:
Ah, good to know! So, to clarify by connectors do you mean charging ports? Or something else?
by
All the parts between the iPhone 4 and 4S are different, the only thing that is the same, is the LCD and digitizer connector, but the frame on the screen is different.
And I mean connector as in the connector on the battery and on the logic board.
by
Appreciate your detailed response Ged!
by
No problem! :-)
by
Add a comment
Add your answer
missG will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 101
