Battery Replaced with a new one from iFixit
Hello Guys, so i bought the replacement kit, and the replace worked well, so i turned on the phone everything worked fine, so 5 hours later the phone goes off and nothing happend it goes on again, and now it wont turn on
What reason can it be??
I thank you for your help
Greetings from Germany
3 Comments
@tess, so you've tried charging your phone and it does not work? what have you tried? Are you using an Apple charger or an aftermarket charger?
by oldturkey03
try putting the old battery in and see if it will power on.
by leevancleef
i replaced the battery and the phone worked for ~5 hours fine , i just texted a message and the phone turned off, i use original apple charger+ cable, when i had charged up it wanted to boot up and fall into boot cycle again and again , when i stick out the cable the phone does nothing
im very very confused
thank you for your help so far
by Tess
