Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2940 Questions View all
missing antenna capacitor what is capacitance?
help missing capacitor that's serial and before to blue coil, the dc decoupling capacitor.... what is capacitance ?
Update (01/29/2016)
Sorry, I was looking for that so fast that i forgot to add pics
see below, the two green circles, i have blue coil and my missing capacitor.... i had no capacitor arround 10pf i believe it is so i put 10nf cap working but not as should be...
Comments:
dandan42 not enough information for a definite answer. Post an image of the part you are looking for with your question. Use this guide Adding images to an existing question to add images
by
Add a comment
Chosen Solution
dandan422 the second green circle is C5_RF (below the "blue coil") and is a 3.0 PF +/-0.05PF 25 V capacitor in a 0201 package. If it does not work because you just replaced it with another capacitor of different value, replace the capacitor with the right one.
Score 3
Comments:
sorry but I'm confuse about the value, is it " .0pf " dot zero ? Maybe i get a damaged board to remove that... i have another trouble... signal of wifi is just a bit lower, works but my friend have same 4s and mine is not stronger as his 4s... replaced antenna and got better but not as i expect, replacing chip can solve or it is passive component issue ? i dropped mine to the floor many times... =(
by
do you have schematic for antenna too ? because in some old antenna 3g and wifi i have some capacitors too... i believe is the same due to application... can you check please ?
by
Proper value for C5_RF is 3.0PF. not sure what other chip you want to replace.
by
Add a comment
Haven't done images here. I keep missing the opportunity from the posts you make, old turkey
Score 1
Add a comment
Add your answer
dandan422 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 295
