Can I fit 655-1803D SSD into MBP 13" Mid-2014?
I have a Macbook Pro 13" MGX72LL/A, A1502 (EMC 2875) with 128GB Sandisk SSD - part number 655-1837D
I am trying to replace it with a 256GB Samsung SSD (part number 655-1803D) - MZ-JPU256T/0A6 originally shipped with Macbook Airs 2013,2014,2015. Is the Samsung SSD firmware compatible?
When I fitted it in, the disk got detected, smart status showed that everything was OK, however when trying to format it, it showed disk IO errors. Is this related to firmware incompatibility or the disk is simply gone?
3 Comments
When you go into About This Mac... > System Report> Under SATA/SATA Express what do you see? Paste a screenshot so we can see it as well. If you still have your Samsung SSD give it a try as well. Something should pop out as being different.
by Dan
Hi Dan,
There is no "About this Mac" menu in Recovery mode. Basically the Samsung SSD is empty and I am trying to install OS X on it.
Regards,
George
by Molo Mollov
Thanks I will try that this weekend.
by Molo Mollov
