The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Questions View all
Tengo problemas con un tic tac en la máquina y no prende
Necesito saber porque hace el Tic Tac y y si hay alguna solución para eso. GRACIAS
I have problems with a ticking in the machine and turns. This is a Mac Pro 3.1 2009.
I need to know because it makes Tic Tac and and if there is any solution for that. THANKS
Add a comment
1 Answer
Chosen Solution
A tic tac usually indicates a problem with the hard drive it could be close to failing. You can use a program like Hard Disk Sentinel to determine how much life you have left in the hard drive
Un tic tac suele indicar un problema con el disco duro podría estar cerca de su defecto. Puede utilizar un programa como Hard Disk Sentinel para determinar la cantidad de vida que le queda en el disco duro
Espero que esto ayude
Score 3
Add a comment
Add your answer
SONASH will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 108
