iMac 24" 2008 refuse de s'allumer
J'ai un Imac qui avait deux ampoules cassé dans le LCD. nous l'avons ouvert et changé les ampoules. Apres avoir installé l'écran, nous avons testé l'imac et il fonctionne sans problème mais quand on referme le tout l'imac refuse de s'allumer.
NB. le réparateur a refermé l'imac et il y a 3 vis qui restent et ils ne sait pas là où ils doivent être mis.
j'ai besoin de votre aide.
Mac will not turn on
I have an iMac that had two broken bulbs in the LCD. we have opened and changed the bulbs. After you install the display, the iMac we tested and it works without problems but when you close the entire iMac will not turn on.
NB. the repairer has closed the imac and there are 3 remaining screws and do not know where they should be.
I need your help.
Update (01/26/2016)
here You have the screws left behind.
The iMac powers up when you push the power button. after shutting it down, pushing the power button has not effect. the iMac will not power up. I need to wait for 1 hour or do a SMC reset.
I will really appreciate your help. Thank you mayer for your input.
1 Comment
Please post a picture of the screws. What do you get when attempting to power up? Any sounds, or lights?
by mayer
