Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
295 Questions View all
spill tea on MacBook Pro but still working!
hi,
I have spill hot tea (with sugar) on my macbook pro. I turned it immediately and wait 72 hours. It turns back on and operating normally (?) Except F1, ... F9. But I can not turn it off, at this time it freezes.
I have read that could clean it with alcohol 90°C or demineralized water.
Is it correct ? If not what should I do to avoid rust?
Add a comment
1 Answer
Chosen Solution
Assuming you meant you turned it off immediately and waited 72hours. Good on you for doing so. However, I would not have turned it back on until I had cleaned the boards. I have fixed my nieces and nephews MacBook Pro since they are kids and spilt KoolAid on it. I would not worry about the rust issue too much since it is mostly aluminium (Aluminum does not Rust). To get it to turn off, I would hold down the power button until it goes off and not use it until you clean it with either suggestion. I personally use rubbing alcohol and it takes patience to ensure you have gotten it all.
Here is a guide on how to do this (although it says water damage the concept is the same) and should get you back up and running smoothly.
Electronics Water Damage (iFixit Guide)
Another quick sidenote: If you have a hairdryer this can be helpful in making sure everything is dry before reassembling. DO NOT USE HIGH HEAT SETTING as this may cause further damage, Low is fine at 6-8 inches from the components (your not trying to melt them, be cautious).
Best of Luck!
Hank
Add a comment
Add your answer
bnj195 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 126
