My MacBook Pro will only start after a SMC reset.
Hi,
Can anybody help me?
My MBP will only start after a smc restart, i can restart him when he is on but when i turn him off he wil not start again. I've tryed everything but nothing works.
NVRAM-reset, hardware test a complete clean install. System check.
Battery looks fine:
Informatie batterij:
- Serienummer: W031642YHD3LC
- Fabrikant: SMP
- Apparaatnaam: bq20z451
- Pack Lot Code: 0
- PCB Lot Code: 0
- Firmwareversie: 201
- Hardwarerevisie: 000a
- Celrevisie: 165
Ladingsinformatie:
- Resterende lading (mAh): 5144
- Volledig opgeladen: Ja
- Bezig met opladen: Nee
- Volledige laadcapaciteit (mAh): 5144
Statusinformatie:
- Aantal cycli: 107
- Conditie: Normaal
Batterij geïnstalleerd: Ja
Ampèrage (mA): 0
Voltage (mV): 125
English:
Battery Information:
- Serial Number: W031642YHD3LC
- Manufacturer: SMP
- Device Name: bq20z451
- Pack Lot Code: 0
- PCB Lot Code: 0
- Firmware Version: 201
- Hardware Revisio: 000a
- Cell Revision: 165
Charge Information:
- Charge Remaining (may): 5144
- Fully Charged: Yes
- Charging: No
- Full Charge Capacity (may): 5144
Health Information:
- Cycle Count: 107
- Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 125
Update (01/16/2016)
Nothing got wet, it started after i replaced my ssd, he works perfect just won't start after i shut him off. Restart also works.
6 Comments
Just looking at the battery info you have provided here its not the battery.
by Dan
Did you get your system wet at some point or do something else to it that might be a factor? How about checking the thermal sensors to see if the system is over heating. Download this app: TG Pro paste a screenshot of the output for us to see in your question.
by Dan
Who's SSD did you put in (Make & Model)? And did you add it Vs swapping out the HD?
by Dan
I put in a Samsung 850 Pro 512GB but first cloned him with Superduper! My old SSD was a Kingston HyperX 240 GB
by Peter Scholten
helo, I have the exact same problem with a Macbook Air 2015
did you find a solution?
thank you
Matthias
by matthias
Show 1 more comment
