The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Questions View all
Keyboard does not work at all in El Capitan!
Mac Pro 2009
I did a clean install of El Capitan. So far so good. I have Snow Leopard on another Partition.
Because I have a tremor I went to the keyboard preference to change the delay until repeat. My keyboard then no longer worked.
My mouse, which is connected to the keyboard DOES still work.
There is no return to default option
Score -1
2 Comments
The keyboard does work in Snow Leopard
by
Who's keyboard are you using? Is it Apple or something else.
by
Add a comment
1 Answer
Chosen Solution
Undo what you did in keyboard preferences and see if it then works.
UPDATE
Here's how to reset your PRAM:
Shut down your machine. Yes, all the way down, not sleep or logging out.
Press the power button and then press command-option-p-r. ...
Hold those keys down until your Mac reboots again and you here the startup chime.
Let go of the keys and let your Mac reboot normally.
Score 3
3 Comments:
It did not work. I have tried many combinations and no luck.
I took a photo of the keyboard setup in Snow Leopard and made sure it was the same but again, no luck
by
Did you check the systems firmware? Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers
by
We still need to know what keyboard you are using as there are also keyboard firmware updates.
by
Add a comment
Add your answer
Ken will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,354
