No backlight, desktop visible with flashlight, external works
Hi there,
I saw a similar post but couldn't find any relevant answers apart from the standard troubleshooting suggestions.
As the title reads, my Macbook is working fine with an external display and I can see a faint desktop on the internal screen if I use a flash. I've tried SMC & PRAM. The screen has been replaced as well.
I tried changing to a new logic board, but unfortunately the one I bought off eBay didn't work at all, no power, nothing so that was a downer.
I read --here --that one could measure the resistance/ Ohm on a particular fuse which is highlighted on a picture there, I tried that and it reads about 350-400Ohm on the one that is circled. I don't know whether this is normal, I checked on the other logic board that I ordered ( which was faulty) and it read about the same on this fuse. Checking other fuses they vary between 0, 100, 150, 200, 300. So I'm not so sure its a fuse issue either. It's somewhat confusing though that not all fuses show 0, or perhaps some of them are made to have a resistance?
Can you help me figuring out whether its a fuse-issue or a bad QFN chip, which fuses should I look at? And if its not the fuse(s) can I get hold of a QFN chip somewhere for this board? I believe its the "APP001" that runs the LCD am I right?
Hope you can shed some new light on this for me
Kind regards
EDIT:
The QFN i referred to is called APP001, 592.4T, 0823A
According to previous post the fuse should be a 2A, 32VDC Quick Blow
Macbook Late 2008, 5.1. Serial: 34841N3M1AQ (I think, found in "About this mac"
Update (01/15/2016)
Thanks for your quick reply, hehe yeah I'm aware of that :-)
The logic board is a 820-2327-A.
See pictures.
The one showing the backside (with the GPU, CPU) is the same model (although faulty with no power) but it should look the same and thought it might prove useful.
2 Comments
viktornordahlbacklund you are a bit all over the map:-). Post some images of your logicboard with your question so we can point some places out that you should test. It will also help if you can tell us what the 820-XXXX logic board number on your board is. To check the fuses checkthis site to see how to do that. You test your SMD fuse the same way as pointed out on that site. To add images to your question use this guide
Adding images to an existing question
by oldturkey03
Please see update above with the pictures and added info.
(Originals should be high-res)
by viktornordahlbacklund
