Laptops manufactured by Asus.
1302 Questions View all
Will only turn on/off with Express Power Key, not regular power switch
ASUS N53S Laptop
I am trying to help my sister out with an issue she is having with her ASUS N53S laptop. There are two buttons you can use to turn it on or off, the normal power switch on the top right if looking at the keyboard, and the express power switch located to the top left if looking at the keyboard. She always uses the normal power switch, but it will currently only turn on or off using the express power key. This loads ASUS Express Cloud Gate instead of directly loading to the OS. You then have to click the "To OS" button to load windows. After shutting the computer down through the start menu, the power switch doesn't turn the laptop back on. You have to go back through the ASUS Cloud Gate to load again. I was wondering how to remedy this issue in order to power up the computer through the normal power button once again. Any help would be appreciated. Thank you.
Add a comment
1 Answer
Chosen Solution
Hi,
If you are using Win8.1 or Win10 Check your power settings.
Start > control panel >power options > change plan settings (on your plan) > change advanced power settings (or change settings that are currently unavailable) > power buttons and lid)
You may also try updating the Intel Management Engine Interface driver (if you are using Win8.1/10) and see if that helps. Here is a link http://www.driverscape.com/manufacturers...
Hope this will help.
Score 1
Add a comment
Add your answer
Michael Wallace will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 252
