Repair guides and disassembly information for Android phones of all shapes, sizes, colors, and brands. Get everything you need to repair your phone yourself.
33606 Questions View all
My phone keeps installing apps by it self, what to do?
'''the phone on or off , the phone install apps by itself without premission ,i tried deleting all apps that might've caused it ,but it's still happening .
sometimes i go to sleep ,next morning there are about 9 apps installed specially :(360 security , halo luncher ,apus )
__________________________________________________________
Note :"i dont have playstore ,i uninstalled it ".
i hope can help me with it '''
Woo Quasar sp6020
Score 39
38 Comments
sry for not putting the type of it ,i will edit it ,my phone is Woo Quasar sp6020
by
hallo everyone, can someone help me or tell me what happen to my lenovo tablet 2 a7-30, it's download and install apps by itself...also my tablet always have popup "locationservice" and it caused my tab leg, i uninstall the apps but still downloading it without my permission...please help me ASAP...
by
same for me only thing is it is downloading Chinese stuff and nasty things such as !!%@ etc. and my phone brand is BLU. Can someone help me ASAP please thank you
by
I have the lonovo A806 and my sister has an Honour phone, our phones are doing this also but mine uses data!!!!!! Someone help! I have factory reset my phone and it is doing it now!!!
by
This is happening too I have a Samsung galaxy s6 edge and it downloads like "letgo, wish, amazonite really anoying and it's not even from the playstore ! And it always shows 'Clean Junk Files' i don't know what's going on
by
Show 33 more comments
Add a comment
Chosen Solution
Hi,
You don't say what type of phone you have!
If it has an Android OS, download, install and run Malwarebytes for Mobiles. This app will check your phone for malware.
Here is the link
If you don't have Play Store installed on your phone use the method below to install Malwarebytes
Download the Malwarebytes 2.00.3.9000 apk file from here to your PC. Copy it to your phone. Remember where you copied it to. Find this setting in your phone and enable it
Then use the File Manager app in your phone to find the .apk file you copied, choose install option follow prompts. This will install the app on your phone. When installation complete, go back and disable the Unknown Sources setting that you previously enabled. Then run the app. It will be located with your other apps
Score 14
9 Comments:
Hi, See updated answer above
by
Thx , i will try it now ,hopefully it'll work
by
after i installed i did a full scan .it showed all the viruses but the problem is when i press delete ,it say uninstall i say ok ,but then it said "unsuccessfull uninstallation"
what to do ??
by
Try doing a system reset. Go to settings>backup & reset> factory reset. Then run Malwarebytes.
by
I have an android as also the payed malwarebites and this aps proceed being downloaded as if the android belongs to them....
by
Show 4 more comments
Add a comment
i had the same problem earlier and found the solution finally. this issue is there in most of the cheep chinese phones and tablets. these phones have pre installed trojan program which cannot be removed from the phone. i tried many applications including trojan remover and so on. No use... but finally i downloaded No root firewall application from google play store(https://play.google.com/store/apps/detai...). this application blocks all the events and unwanted programs including download manager which downloads unwanted programs without your concern. now i dont have issue. i allow the download manager whenever i want and other time i block download manager and other trojan suspected programs. this solution might help you.
Score 5
2 Comments:
Thank you so much for sharing about this app here. This is the only app that has blocked virus apps from getting installed by itself. I had used all sorts of antivirus, Malwarebytes, even did a factory reset to get rid of these viruses but they were getting install by itself. NoRoot Firewall is the only app that has resolved this issue. Thank you once again (I specially created this account just to thank you).
by
Hey. I'm unable to click the Ok button. Why's this?
by
Add a comment
I had the same problem of random apps getting installed without my permission on my samsung s7. Tried factory reset, changing google password, mcafee and malawarebytes. None helped. Then i installed noroot firewall app as Mr. Kesavan suggested here - and mercilessly denied all android and samsung apps. Only chrome, clock, outlook, google maps, wordament and a few more safe apps are allowed thru firewall. This solution is working.
Every little app seems to be trying to do connections unnecessarily.
Thank you Kesavan!
Score 3
1 Comment:
I have a Ultimate Mobile Xperience Go Edition byassurance wireless by Sprint. Android Version 8.1.0 my weather app is being piggy back by someone. How do I know this, because I uninstall my Weather app and the real app appears. How to fix!
by
Add a comment
Hmm. I'm wondering if you have an apple phone. Is it redownloading apps you've already purchased. Even free apps?
Score 2
9 Comments:
its all free apps ,some i didn't know of before ,it started installing them suddenly ,although i think it happend after i downloaded 360 security by mistake , By the way my phone is an Woo Quasar SP6020
by
Hi,
Did you see and try the updated answer about how to install and run Malwarebytes when you haven't got Google Play Store?
Here it is:
Hi, Download the Malwarebytes 2.00.3.9000 apk file from http://apk-dl.com/malwarebytes-anti-malw... to your PC. Copy it to your phone. Remember where you copied it to. Find this setting in your phone and enable it
[image|740861] (see 1st answer for image)
. Then use the File Manager app in your phone to find the .apk file you copied, choose install option follow prompts. This will install the app on your phone. When installation complete, go back and disable the Unknown Sources setting that you previously enabled. Then run the app. It will be located with your other apps
by
@theimedic, I would hope that you join the group I created. I created because Master Techs has too many wanna be techs. @jayeff, I'd hope you join too.
https://www.ifixit.com/Team/21339/Master...
by
Shoots. I'll join lil bro. Been a busy hectic at the shop. Haven't been on the site in awhile
by
Or playin Titan fall
by
Add a comment
By the way, the reason why some viruses are cannot be uninstalled is because they have placed themselves in the system directory and for you to remove them you either need to remove them with an application which has root access or another way. I have my phone rooted as it was the only way to remove some issues I had back in March/April.
I have a similar problem, using any malware software does not detect any problem, I uninstall the 3 applications on my phone 'go security, ace cleaner and superb cleaner' these three application no matter what I do keep re-installing after rebooting my phone.
I have uninstalled them successfully . I had this issue either after uninstalling Go Security or 360 security. I cannot remove them, I have tried removing the directories but something is hidden on my phone and I cannot find the source for it which keeps installing them, my mobile boots up saying optimising app 1 of 3.... then after the three it loads up with the 3 that i removed back on the phone.
It is something that advertisers have probably secretly put on the applications which the software developers cannot trace so the applications end up being placed deep into the phone. But I am not sure of the source
Score 2
3 Comments:
Could've just installed malarebytes to extinguish yhem
by
The source is hidden thumbnails and Caches. Also on your Google play account
by
It's a app called Insta app that's creating my similar problem
by
Add a comment
I had the same problem apps install themselves on android I found out it was The update of googleplay installing them So when I reinstall OS I dont update GP I get the warning apps wont run but I just back out of the warning an they still run (no installs since)
Score 1
Add a comment
If on android and your getting the system_protect.apk downloading go to settings> apps and scroll all the way down, there an app with now name about 29Mb , this is the malware, malware bytes doesn't see a file without a name so it skips over it !
Score 1
1 Comment:
App without permission automatically installed please hep,me sir.?
by
Add a comment
Fix Random Apps Keep Installing by Themselves
  1. Uncheck Installation from unknown sources. Launch settings in your phone and go to 'Security'. ...
  2. Revert your ROM and Flash. Bad apps installation also stems from different ROMS. ...
  3. Delete Related Apps. ...
  4. Sign Out Google Account, Change Password. ...
  5. Disable Automatic Restore. ...
  6. Restrict Background Data. ...
  7. Install a Good Security App.
Score 1
1 Comment:
My phone has been doing the same thing, install an app then uninstall a few minutes later. Even says I have accessed the app and used it before uninstall. Happens in the middle of the night when my phone is in the opposite end of the house. Has caused A LOT of problems in my family. Has been happening for months. Why is this happening on my android phone? Google support just says I must be doing it.
by
Add a comment
Add your answer
adelrabaya will be eternally grateful.
Past 24 Hours: 20
Past 7 Days: 169
Past 30 Days: 1,003
All Time: 338,892
