Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3351 Questions View all
iPhone 5 black screen beeps on charger
the phone simply goes black when i try to unlock him and when i put him on charger he starts to beep every few seconds and gets hot. then i reassembled and disconect the lcd flex cables and connect them again but the problem is the same. then i changed the few working lcds but he beeps again and gets got. then i chacked the logic board all connectors and components are ok. l41,l42.l43,l44,l45 are beeping that is good i think,and i forgot to say that the backlight is dim and se the light in dark room. can you help me somehow i dont know what the problem is?
the phone isnt water damaged or droped
Comments:
can anyone tell me where to look ?
by
Add a comment
PC Laptop Batteries
An easy fix for a big power boost.
Shop Now
PC Laptop Batteries
Shop Now
Most Helpful Answer
Hot = a short. Find and relieve the short. Beeping means a line is down at LCD
Connector find missing voltage, it is probably on the shorted line
Score 2
Comments:
can you tell me where to star or what component to look ?
by
Start by finding what is short to ground that shouldn't be. Compare to schematic. Start at LCD connector and work backwards using schematic
by
i made it, the fauty component was c351 my screen now works and no beeps, you are the queen :D..... But i am facing with new problem :( my touch now work. i changed few screens and nothing , checked all component again, clean the connector and still not work??? what that can be? can you tell me some solution ??? i am very grateful with your help thanks alot :D
by
Same thing--work backwards from touch connector and look for missing voltages. Touch rails are something like SAGE_5v7 and neg 5v7
by
do i need to check rails with connected battery or disconected battery, or on or off phone ??
by
Add a comment
Same thing happened when my phone screen broken. It beeped because there was no signal from lcd. Try with new screen, and check the lcd + digitizer connection on your phone clean it with alcohol.
Comments:
the whole board gets really hot when is on charger and when it beeps?
by
Add a comment
Add your answer
Vladan Vojinovic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 174
