Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
After replacing UEFI BIOS chip does not start the installation.
Hello, I replace the BIOS chip because my client don't remember the EFI password and now with the new BIOS doesn't start the installation. The computer is too low. I put a new installation finished in USB hard disc and start but in a few seconds only appears the Apple logo and don't do anything. I replace with two BIOS and do the same. The apple test appears GOOD. Please help me. Thanks.
2 Comments
if you got that far, sounds like you just need to do a normal system restore, use the WIFI to download the OS and let it install the latest update on to that imac, but before doing this , you might want to go to disk utilities and ERASE your entire SDD or HDD so it can be a CLEAN fresh install ...
by
Failed bios chip install. This is a VERY delicate procedure and if not done with the absolute correct tools you can lose USB boot-ability, CPU gets iverheated, tons of weird stuff. Send it to a pro who dies this for a living. Each bios is flashed based in the machines HASH code....
by
Add a comment
Chosen Solution
All your customer needed to do was call Apple and get it re-set. Why didn't you tell him to do that?
Score 4
3 Comments:
That’s a great answer if he asked what his options were prior to doing the bios chip. If you’re going to take the time to write an answer, awesome! If you’re going to write something irrelevant to the question, nobody wants to take the time to read it so don’t.
by
Alex, this is an open forum, please feel free to write a better answer. I also have problems with the integrity for this type of repair.
by
With all due respect, you didn't write an answer to his question. You wrote your comment based off your opinion of an assumption you've made. I fully understand why you said it but with as little information as was given, in regards to the reasoning behind the decision to do so, your comment reads as very condescending and more so just rude. Also, I know this is an open forum but it's a forum to help people not to belittle them.
by
Add a comment
Are you using a Bios chip from another board? If so it won't ever work right you need to find a service that reprograms a new chip with a Clean ME region if you did buy the chip from from a seller and it's running like that it was not properly programmed. You also need to install with clean wiped hard drive otherwise your pairing the EFI lock again.
Score 3
2 Comments:
hi, what if we tried with new bios chip but imac will not power on, does this mean bios chip is faulty ? also what if the new bios chip is installed with old hard drive cant i get to restore ? or disk utilities without it EFI locking with the same old code .... HELP PLEASE !
by
could be upside down also check make sure pins are not shorting
by
Add a comment
this sort or repair comes with its risks. first of all there is so much heat after two attempts you will need to check the resistors and traces. also chck cont between testpads to the chip. this is normal if you know what you are doing. I think you fried something
Score 1
1 Comment:
Bingo. Even though this is several years old it's still good info for the future, but this type of repair needs to be done at a sealed shop type lab environment with all the correct re-flow machinery etc etc. A simple home shop will never be enough to do this type of repair and things, need reflowed, reflashed, programmed etc and like you said, HEAT will most certainly kill it long before anything is even close to being able to boot. IMO it's not even worth attempting. Send it off to aplace like galaxyhp who has all the machinery and clean lab to do this type of repair or junk the machine. It'll never work otherwise 99.9% +1
by
Add a comment
Add your answer
carbo2022 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 3,480
