The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
269 Questions View all
My brother dropped a glass of wine, can I fix it?
My brother dropped a wine glass on it and in the Apple store they told me that to fix it I have to change the motherboard and the keyboard. They give me a 800 eur budget.
Is there a way to get the pieces for myself (where?) and fix it for myself??
Is there any tutorial??
Thanks
Comments:
Did they take it apart and look at it? What was damaged on the mother board? Simple liquid damage type services may fix the current board, which is where the bulk of the cost is. Keyboard replacement is possible but a tedious pain in the butt. If I'm not mistaken the keyboard on this model is riveted to the frame but can be removed and the rivets replaced with screws. Either way you have to gut the entire machine.
by
yes they did, where could I buy a motherboard then?
by
Add a comment
Chosen Solution
You can get a logic board here, but inspect it yourself before buying anything: MacBook Air 13" (Mid 2013/Early 2014) 1.3 GHz Logic Board
MacBook Air 13" (Mid 2013/Early 2014) 1.3 GHz Logic Board Image
Product
$299.99
Score 1
Comments:
it says out of stock, but thank you
by
Add a comment
i am in west Africa Ghana with similar problem how can i buy a logic board from the website,my country is not in the shipment list.
Comments:
Hi Eric,
You can try buying the logic board here:
https://www.commandmacparts.com
Good luck!
by
Add a comment
You can try www.powerbookmedic.com They're on the pricey side but have always been reliable.
Add a comment
Hi Victor,
Sorry about your spill and hopefully you can get it fixed soon. You can swap a new motherboard in if you follow the tutorial here on the website:
Link text
As mentioned by @krisfuqua, replacing the keyboard is going to be time consuming and a pain in the butt. You will have to take pretty much everything apart to get to the keyboard.
You can purchase the motherboard and keyboard parts here:
Your motherboard price will range from $347-$700 depending your macbook air 2013 model. International shipping will cost between $50~100.
I hope this helps.
Add a comment
Add your answer
Victor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 127
