The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
223 Questions View all
Can I replace my headphone jack?
The headphone jack (located below the power button) on my PPC G5 is damaged.
Can I repair or replace this part myself?
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Chosen Solution
Get an extension cable for your headphone and use the rear port. You can replace the panel. Here's the part on eBay: http://cgi.ebay.com/G5-PowerMac-case-Par...
Here's another: http://www.welovemacs.com/9225979.html
UPDATE: Removal
Using a jeweler’s flatblade screwdriver, pry up the metal cap covering the front panel board EMI shield.
Using a Phillips screwdriver, remove the two front panel board mounting screws.
Carefully pull the board a short distance out of its EMI shield, and disconnect the power button cable from the board.
Remove the board and shield from the enclosure. That's it.
See page 75 of Apples Power Mac G5 Take Apart: http://www.baconeggs.co.uk/images/dmm/po...
Score 1
Comments:
Add a comment
Most Helpful Answer
Only you know your skill
level and tool set. If you feel uncomfortable soldering logic boards take it to a computer repair shop.
'''If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Score 1
Add a comment
Thanks so much for the assistance.
The G5 PowerMac case Part FRONT PANEL USB FIREWIRE BOARD referenced by rj looks like what I need.
Can I access and easily knock out the old part? In other words, is this a simple operation like plugging in an HDD or RAM, or is this part difficult to access?
Comments:
Hi, To give proper credit mayer provided the link for the panel. I will however leave you a link for the service manual. Hope it helps. Ralph
http://manuals.info.apple.com/en/Power_M...
by
Add a comment
Add your answer
Slob Jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,182
