GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 Questions View all
iPad 4 after Digitizer replacement some areas don´t react
Hello guys,
i replaced my iPad 4 front panel after it was broken but now i have the problem that the new digitizer only reacts at the top and bottom area, in the middle of the screen it doesn't response. I thought the Digitizer is damaged so i took a new one but same problem only in different areas.
What can it be? Is it again maybe a damaged digitizer or maybe a short circuit some where or something else?
Really appreciate if you can help me out.
Add a comment
1 Answer
Chosen Solution
Most likely the digitizers your using are from third party vendors, and you're having third party problems. I would try a quality digitizer. It is possible that you've damaged the alligator connector, while assembling it
iPad 4 Screen Digitizer Assembly
iPad 4 Screen Digitizer Assembly Image
Product
$39.99
Score 1
1 Comment:
Thank you for your help. I will try a new one.
by
Add a comment
Add your answer
fuad1177 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 99
