Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2950 Questions View all
Can't hear phone calls on loud speaker or ear speaker.
My loudspeaker failed on me so I replaced the speaker enclosure. This fixed the loudspeaker issue, but suddenly I can't hear when placing, or receiving a call, either on the ear speaker, the loud speaker or a blue tooth headset. I know the call goes through as I've called my other phones, but as the caller I can't hear anything coming from my cell phone either. I never had an issue in the past, so it's something I did during replacement of the speaker enclosure. I've had many 4Ss apart before, and I went back in on this one to see if I may have done something wrong, but it all looks ok.
Any ideas??
Add a comment
1 Answer
Chosen Solution
Try resetting your settings for starters
Score 1
Comments:
I tried resetting both the network settings and the overall iphone settings; no joy either way. I also removed and reinstalled the sim card. Oddly enough, I get data but no calls... If I damaged the antenna somehow removing it from the speaker enclosure, would that do it??
by
Well, if you damaged it, you wouldn't be able to send/get sms or get Internet or wifi. Are you able to get any of those?
by
Yes I'm able to text and surf the Internet via cellular data and via Wi-Fi. That's a good point, my antenna must be OK. Any other ideas.? Up until now this is been a great phone. The phone calls go through and come in there's just dead silence: I can't hear and I can't be heard.
by
Unplug the lower dock (charging port) then make a phone call and see if the ear speaker works. My suspicion is that the charging doc may be shorted out and has the phone acting like it is plugged into a bay. I've seen this happen a lot.
by
Gosh, this is weird. Have you tried resetting your cellular data settings?
by
Add a comment
Add your answer
ponche35 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 64
