Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3202 Questions View all
Why does my iPhone5 keep powering up and shutting down by itself?
After completing my screen replacement due to it being severely shattered, I was not able to get the iphone to boot up. When connected to the charger the iphone turns on and off repeatedly, once the charging sounds it shuts off & the LCD does not turn on. I have never experienced this issue for the 6 years I have been repairing iphones.
So far I have tried another charging cable, I replaced the iphone power port. The battery does have a some bubbles building up, I have a battery on the way, not sure what else to do ?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Definitely a battery issue. Hopefully it can be solved by just putting a new battery in. Otherwise you've damaged something with the battery connector, on the logic board
Score 2
Comments:
Thanks! I hope it is the battery.
by
I replaced the battery along with the power board, still experiencing the same issue. When I plug the charger, the iphone just makes that charging sound to alert you the phone is charging. It just keeps on making that sound, no display at all.
by
Try a force restart
by
Add a comment
Add your answer
Ernesto will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 53
