Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4811 Questions View all
iPhone 6 Loud speaker broken after housing replacement
Hello replaced my housing with a new housing everything worked but the speaker, it only worked for a bit and sounded muffled. Then just completely stopped working, tried a speaker replacement no luck, tried a new charging port connector no luck. Any advice?
Score 1
Add a comment
PC Laptop Batteries
An easy fix for a big power boost.
Shop Now
PC Laptop Batteries
Shop Now
1 Answer
Chosen Solution
Wondering if it's just a connection issue
Score 1
Comments:
Have an iPhone 6 the housing bent, after the housing bent it said no SIM card even though there was a SIM card in the slot, I took the motherboard out of the housing it was slightly bent near the charging connector/ battery connector. I put the iPhone in another housing, inserted the SIM card now it just says searching even when I pull out the SIM card keeps saying searching. I'm planning on installing a new charging port I thought it might be an antenna issue. Any advice? Thank you
by
Could be an antennae. You also may want to try resetting the phone
by
Add a comment
Add your answer
Dewells will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 111
