Repair guides for Windows cell phones manufactured by Nokia.
592 Questions View all
Lumia 930 dropped in bath, turns on now, but does weird things.
Good evening,
Lumia 930
I was dumb enough that tried to answer phone call while i was in bath, so it happened, that phone slipped out and drop inside it. I got it out in few sec. and turned off, took off back cover and placed in bag of rice for 3 days. It was impossible for me to take off battery at that time, because i had no tools(screwdriver) to do it.
Now i have tried to turn it on, and it works, but there is one problem with it.
When it's turned on all screen is greenish color, and as i start to use it it starts to work by itself, opening apps, calls and everything, so my guess is that screed is dead.
Question is: Is it really screen, or it could be any other part of phone, that is damaged? Will screen replacement work for me?
Add a comment
1 Answer
Chosen Solution
@eximpo, sounds like you got your work cut out for you. First off, "placed in bag of rice for 3 days." does not do anything. It is a myth, and nothing but a myth. Rice is only good for cooking and has no place in electronics repair. Using rice is the equivalent of not doing anything. It's a waste of good rice.
What you want to do is to totally disassemble your phone and clean it with 90%+ isopropyl alcohol and a small brush. Check to see if this video will be helpful to you. Remove all EMI shields to do so. Use this guide to help you with that. It was written for an iPhone but all the steps are pertinent to your phone as well. You must clean all connectors and all flex cables. While you are cleaning it, checking your circuit board for any missing or burned components.
If you do not clean your phone, you cannot properly troubleshoot it. Any part may have failed due to water damage, and the longer you wait further parts may fail due to corrosion. It will continue to fail until it will be totally destroyed.
Yes, it is possible that it is your digitizer that is causing this, but it is also possible that this is caused by shorted out digitizer circuits or the IC itself.
Score 3
Add a comment
Add your answer
Arturs Balodis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 446
