Is going to be more faster?
If i upgrade my memory ram of my macbook late 2009 is going to be more faster???
(change to 2 to 4 ) can i feel the difference??
if U want to see some differences about speed, U must change your hdd with an ssd. For example I did the same with my macbook pro early 2011. Now it's totally different. It's double faster!
If you change also the ram as well, I'm sure that the result it will be amazing.
The only important thing when U change the ram it's that the new RAM must have the same frequency of the older one.
Everything clear?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 46
1 Comment
RAM mostly just deals with the amount of things you can do at once. So if you have several apps on your laptop running at the same time, you will notice a difference in speed if you upgrade the RAM.
by Austin Bates
