Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1232 Questions View all
iPhone 5c keeps shutting down during power on
I have recently had problems with my iphone 5c with the battery running down low very quickly. I had my battery switched over twice, the first time was with a battery out my old iphone this battery did not work with my new phone. we then put the original iphone battery back into the phone and it turned on no problem, although it would no longer charge, the charging symbol came up and my phone wasn't running out but it wasn't charging either. The next day when I tried to turn my phone on it booted up then switched itself down 4 times before then turning on (it then ran out straight away). When my new battery arrived and we put it in the phone booted up then shut down again before it had chance to boot up fully. This is all my phone will do now. What can I do to fix this?
Score -1
Add a comment
1 Answer
Most Helpful Answer
Where did you buy the battery from?
I'd venture to guess it's another bad battery.
Score 1
4 Comments:
it was from ebay but the original battery that came with the phone had a problem with it
by
A device not charging is an issue with the dock connector (charging port) and an issue with the device shutting down automatically is usually related to a bad power supply (battery). I would say you probably originally had a bad dock connector and/or battery and now you have the same issue. Try buying a replacement dock connector and battery and seeing if that resolves the issue.
by
I have is problem, however my battery is fine, because it charges my other iPhone 5C, I changed the charging port and have not been able to get the phone to work since
by
What was the original reason for changing the charging port?
by
Add a comment
Add your answer
Sophie Pennington will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 80
