ipad air ghosting issues
I am fixing an ipad air 1st gen. I bought a cheap screen for like $15 on ebay. I installed it and when i press the bottom corner itll start ghosting. I bought another one and same problem. I researched and foubd that taping the cables and edge of digitizer to not touch the frame will do it. I did that and still ghosting. I took it to the shop and he said my tape job is fine, and said maybe its a low quality screen. I already bought 2 screens, im worried if i spend $35 (the most expensive one i can find on ebay) itll still have the same problem. It only happens when i try to seal it and the bottom corner touches the frame. No cables and digitizer is touching the frame, im sure if it! Where can i buy a oem quality screen that will make it stop ghosting or what am i doing wrong?
I have replaced many iPad digitizers. I have only replaced three iPad Air 1 digitizers. Everyone of these, if the iPad is in landscape mode with the home button on the right, the "a" part of the screen does not work when the keyboard is needed. If you place your finger behind the iPad and press the "a" with your thumb it works. The "a" button works in portrait and the other landscape mode with the home button on the left. Has anyone else had this problem? Thanks in advance for your help.
by Marko
