HMDX Jam HX-P230 is a wireless Bluetooth speaker manufactured and released by the HMDX Company in 2012. Also known as JAM classic portable speaker.
37 Questions View all
Question Closed
pairs with phone but doesn't play anymore
I've been using the Jam Classic wireless speaker with my Samsung phone and Pandora for over a year and all of a sudden it won't play. It is paired and even pairs with my husband's I-phone and plays but it no longer plays with my Samsung android phone?
Score 1
Add a comment
The reset described below worked...
http://macdrug.com/bluetooth-connectivit...
Until El Capitan, OS X 10.11.
Apple is having problems with some unspecified Bluetooth problems. With lingering problems after their latest update that addressed Bluetooth problems. Perhaps they will fix it over time?
Apple has disclosed about some of the connection issues they are having. i.e. Sandisk Memory cards were in the same boat. https://discussions.apple.com/thread/725...
For all other operating systems just follow the manual instructions that came with that mighty little speaker. My JamBox worked fine for years, until the micro usb connector came loose then broke.
Jam Classic Manual,
[http://www. described.com/customer-support/instruction-books]
Depending on your device you may be prompted to enter a pairing code. If prompted enter “0000” as the code.
Press and hold the PLAY/PAUSE button for 5 seconds to activate pairing mode.
I looked up your phone, and it had more details you may need.
Good luck!
pauzed
Add a comment
could need to re-wire it from the inside, my JAM broke and i re-wired it an now its working again
1 Comment:
good job! lets both commit to making a guide.
by
Add a comment
  • My speaker Isn't playing music or making any sounds when I connect to it, any solution such as a reset that will fix it??
Add a comment
I'm sorry I think your in the wrong section, or not.
please read my answer above too, if your using Mac's 2 latest operating systems. Yosemite & El Capitan, they are working on some bugs.
Do you have a power light come on? It's red, and blue if bluetooth is working from your unit.
Are you sure your Batterie is charged?
If you threw away your instructions they are downloadable at Jam's website, here is a link...
Your problem is different than the 1st question, there is some grey area there however I hate to say this, your question is in the "Add your answer" section. So you have credit for 1 answer.
I am just as new as you are, an easy mistake to make. This is the best site on the web!!
Pauz
Add a comment
hey use this app >> http://techmsoftware.com/cleanmymac-3-cr...
Add a comment
Battery is dead..... the usb charge juice power is not equivalemt to the supperior 1000mah batt and it's current so it will self shutdown from lack of power on a high volume...
5v at 1.0ma vs 3.7v at 3w
http://ugemrp.com/1066/0000/0014/0066/00...
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,136
